Post by denz on Aug 1, 2010 20:21:58 GMT -5
50 trim stage 3 .60T .63E boost set to 20lbs did a data log with ms and it says that in a 3rd gear pull at 4000rpm 16.8lbs boost. At 5362rpm where i let off 19.6 , Does this seem slow?
Post by Stinger on Aug 1, 2010 22:41:25 GMT -5
What airflow mods do you have (head, cam, exh manifold, etc.)?
Post by denz on Aug 1, 2010 22:55:32 GMT -5
ported head, big valves, ported/gutted intake, 65mm T/b, stinger header, 3 inch all the way out straight threw muff, ranger roller, Large front mount, 2.5 tubbing.
Post by Stinger on Aug 1, 2010 23:27:44 GMT -5
Yeah, you should have full boost closer to 3000 rpm in 3rd gear if you floor it around 2300. Did you forget to put the valve seat in the wastegate before you bolted it on? Just checking if it's leaking out of the wastegate at idle will tell you if you aren't sure.
Post by denz on Aug 2, 2010 16:50:43 GMT -5
sitnger I have not messed with the wastegate since i put it on. This seems to have started rercently. I used to be able to nail it on a roll in 2nd and it would spool up and smoke em. And I can feel it is spooling slower. Could it be my tune, timing possible.
Post by Stinger on Aug 2, 2010 17:52:06 GMT -5
Should most likely be caused by an exhaust leak between head and turbo then...blown gasket, crack, etc.
Post by denz on Aug 2, 2010 18:26:37 GMT -5
ok ill have to look in to that.
Post by denz on Aug 2, 2010 19:37:16 GMT -5
looks like a leak at #3 on the top. Of course its a bolt thats super hard to get to. i was going to warm it up and try to tighten a little more but thats out of the ? Looks like time to change a gasket.
Post by Stinger on Aug 2, 2010 21:17:39 GMT -5
If it's been leaking for very long then the gasket is trashed. You'll have to replace it.
Post by denz on Aug 2, 2010 22:08:26 GMT -5
well after fighting it i managed to 2 half turns on it so we will see in the morning. Stinger u r right most of the time u have to replace it. what one do u sugest.
Post by Stinger on Aug 2, 2010 22:48:20 GMT -5
A standard felpro gasket is fine. If you want to have itground flat while it's off, you can install it with no gasket. Just put a little copper spray or high temp rtv on it.
