Post by merc460 on Aug 7, 2010 10:28:52 GMT -5
Here is a set of ARP main studs Part # 151 5402. I had the oil pump pick up stud modified by a local machine shop to allow the use of a hold down bolt and washer. Sold Here is a powder coated Valve cover that has been tapped for a fitting There are some chips in the powder coating [ see pics] but still in very nice shape also included is a used once re useable Ford OEM valve cover gasket Sold Here is a 7.5 373 Track lock gear set in good used condition no chipped gears and the posi seems tight, but it should be gone through because of the wieght Sold
Post by merc460 on Aug 9, 2010 14:48:02 GMT -5
Posi Sold
