Post by sonic23 on Aug 8, 2010 20:39:55 GMT -5
I bought a 92 with the turbo swap done with a 85 svo and la3 computer t3/t4 hybrid turbo, 55lbs injectors, the guy couldn't get it to start. well it turned out the fuel pump was out, had an ignition ground and some small little problems so i fixed all of those.
It will start and run but it starts and will run once every other week and is extremely rich! When you shut it off it will almost start again, and if you try again it just cranks. The air/fuel is pegged on Rich!
I have the timing set according to the guide on the website, fuel pressure is at 40, and have checked all wires, but the computer will not communicate with the scanner my cousin said so i cant see if any codes are showing up and check engine light is not on.
Thanks
Post by Stinger on Aug 8, 2010 23:42:23 GMT -5
No codes equals fried ecu.
