Post by shizznizz980 on Sept 10, 2010 20:22:08 GMT -5
ok stinger so I noticed that the tps i currenty have in the car is the thunderbird tps with the mustang throttle body and it is on there with one screw......so if I switch to the mustang tps which is non adjustable I can just throw it on there and be good?
Post by Stinger on Sept 11, 2010 11:31:37 GMT -5
Bolt pattern should be the same for both tps/throttle bodies unless you are running 5.0 tb.in that case you'll need a different tps which also has a different plug.
Post by oneowner88lx on Sept 20, 2010 21:20:31 GMT -5
