la3?
Aug 21, 2010 21:23:49 GMT -5
Post by dsmgrimreaper on Aug 21, 2010 21:23:49 GMT -5
so i was given a box of parts with the merkur when i bought it. the ecu i was told was needed to run an intercooler and the big vam which was included. so i pluged them in and......... nothing car ran like crap and died at every stop sign and stop light. i tried using just the big vam and still crap so do i have useless parts or can they be used with some mods
la3?
Aug 22, 2010 0:10:34 GMT -5
Post by blueovalfan on Aug 22, 2010 0:10:34 GMT -5
r u using the correct 36lbs injectors?(brown tops) because if your not it will cause all the symptoms u just described.
la3?
Aug 22, 2010 0:57:37 GMT -5
Post by Stinger on Aug 22, 2010 0:57:37 GMT -5
You have to move some pins around to use the LA3 ecu. It's not a plug in and go swap. Hopefully you didn't fry the ecu by installing it without any pin changes.
la3?
Aug 22, 2010 9:42:54 GMT -5
Post by dsmgrimreaper on Aug 22, 2010 9:42:54 GMT -5
yup my car has brown tops and no the ecu is fine i had a friend try it in his tc. whats the advantage of using this ecu.
la3?
Aug 22, 2010 11:19:00 GMT -5
Post by Stinger on Aug 22, 2010 11:19:00 GMT -5
It's just a newer faster ecu that is made to take advantage of an intercooler and the larger air meter. It's got a more aggressive timing map for intercooled cars.
la3?
Aug 22, 2010 15:06:21 GMT -5
Post by dsmgrimreaper on Aug 22, 2010 15:06:21 GMT -5
hell with that ill sell it to ya with a big vam cause im waiting for your ms system so i can run speed density
la3?
Aug 22, 2010 22:54:20 GMT -5
Post by Stinger on Aug 22, 2010 22:54:20 GMT -5
Who are you selling it to?
la3?
Aug 22, 2010 23:45:04 GMT -5
Post by dsmgrimreaper on Aug 22, 2010 23:45:04 GMT -5
who ever wants it really i dont even know what these things go for
la3?
Aug 23, 2010 1:06:45 GMT -5
Post by Stinger on Aug 23, 2010 1:06:45 GMT -5
LA3 is worth 60 or so, big vam about 30.
