Post by cjdavid on Aug 27, 2010 17:32:34 GMT -5
Which wiring harness would be the best to use? I have a f/I harness from a '87 4 cyl. And I also have the harness from the '88 T/C donor car.
Sorry for the stupid question but I suck at wiring (at least it seriously intimidates me) So I would like it to be as much plug and play if that is at all possible
Post by merc460 on Aug 27, 2010 19:06:05 GMT -5
What car is it going in? If its a mustang use the 87 harness it will be easier to ad the wires for the vam and move a few pins, than trying to make the 88tc harness work, there is a lot of extra stuff in a 87 88 TC harness that makes it not really desirable as a swap harness.
Post by cjdavid on Aug 28, 2010 9:33:42 GMT -5
Yeah that would be important info. The car is an '86 that was a 4 cyl, carb'd
Post by cjdavid on Aug 28, 2010 9:34:29 GMT -5
Yeah that would be important info. The car is an '86 that was a 4 cyl, carb'd. Thanks for the info. I'll look into the FAQ section to see what needs to be changed on the '87 Mustang harness, Thanks
Post by merc460 on Aug 28, 2010 14:39:31 GMT -5
My first 2.3t swap was an 86 carb and it was interesting. First you will need to add a fuel pump relay and the fuel pump wiring back to the tank, that being said you will need a efi tank or an external fuel pump. There is more just take it one issue at a time and you will be fine.
Post by oneowner88lx on Aug 28, 2010 14:40:14 GMT -5
Post by Stinger on Aug 28, 2010 16:20:20 GMT -5
There is a sticky thread at the top of the tech forum on TF covering this swap. I'd start there.
Post by cjdavid on Aug 29, 2010 8:41:59 GMT -5
My first 2.3t swap was an 86 carb and it was interesting. First you will need to add a fuel pump relay and the fuel pump wiring back to the tank, that being said you will need a efi tank or an external fuel pump. There is more just take it one issue at a time and you will be fine. I have a fuel injected (like an 87) 4 cylinder gas tank that a friend gave to me so I have a F/I tank for that part. Thanks for the info. Now that the water season is coming to an end I want to get this project done and running.
Post by merc460 on Aug 29, 2010 19:26:34 GMT -5
you will need to swap the fuel level sender from the 86 tank to the 87 tank the 86 fuel gauge uses different ohm rating.
Post by cjdavid on Aug 31, 2010 17:46:17 GMT -5
for give my ignorance... all I will need is the fuel level sender from the 86 and use the a F/I intank pump...yes??
Post by merc460 on Sept 1, 2010 8:06:34 GMT -5
Yes use the 86 sender in the 87 F/I Tank
