Post by dsmgrimreaper on Aug 28, 2010 22:55:53 GMT -5
so i might have come into owning another merkur with a built motor that comes enought new performance parts over size ss valves and stage 3 cam and such. the car itself has same parts in it running a huge holset. my main question is if there is a hp limit on the cast iron head and with stage 3 cams how reliable are they built
Post by Stinger on Aug 28, 2010 23:52:08 GMT -5
so i might have come into owning another merkur with a built motor that comes enought new performance parts over size ss valves and stage 3 cam and such. the car itself has same parts in it running a huge holset. my main question is if there is a hp limit on the cast iron head and with stage 3 cams how reliable are they built Can you explain what the bold sections in your quote mean? Also, how reliable are what built? The cam, the head, what?
Post by dsmgrimreaper on Aug 29, 2010 9:30:53 GMT -5
the iron head. ive herd alot of talk about them cracking and i want to avoid that as much as possible
Post by Stinger on Aug 29, 2010 14:27:54 GMT -5
They don't crack from too much hp, they crack on bone stock engines because of a lack of valve seat inserts and the heat a turbo puts on the exhaust valve.
