Post by 79turbostang on Aug 30, 2010 1:31:24 GMT -5
OK i got a 84 all stock svo with 70000 miles on it, like only 70000 actual miles on the car and motor. so i was bored today and was starting to notice a little lag in the turbo so i did a compression test number 1 cylinder had 118psi number 2 had 121psi numbers 3 had 155psi and number 4 had 115psi i did put a tablespoon of oil and retested and the pressure came up to 152psi but i didn't put oil in the rest of the cylinders and also noticed lately that when ever i start the car a puff of blue smoke comes out but after a few seconds its gone
So what should i do...and why it there such a big jump in number 3 the car also sat for about 9 years I'm thinking the whole motor need to be rebuilt
Post by Stinger on Aug 30, 2010 1:52:45 GMT -5
Typically they will read 135-155 so #3 is probably the only "right" one. I'd retest to verify numbers before proceeding.
Post by 79turbostang on Aug 30, 2010 13:20:53 GMT -5
should I just do a regular compression test or should I put oil in the cylinders and test
Post by Stinger on Aug 30, 2010 13:38:53 GMT -5
Regular is fine, make sure the engine is warm and you hold the throttle wide open during the test.
Post by oneowner88lx on Aug 30, 2010 21:14:19 GMT -5
I would unplug the injector harness so you aren't squirting fuel in the cylinders while you are cranking.
Post by Stinger on Aug 30, 2010 22:48:20 GMT -5
Holding it wide open shuts off the injectors...it puts the engine in "flood clear" mode.
