Post by mrsvo on Sept 7, 2010 2:47:46 GMT -5
whats up guys i just recently got my dirty little hands on a beautiful 84 SVO, and recently i have been having some problems...
the first problem was that it wouldnt stay running and i couldnt find the problem but come to find out it have a vaccum leak were the intake tube off the turbo wasnt sealed so i temperarly fixed it by just putting the VAN(MAF??) box directly on the turbo with a coupler and it ran fine nut now after running it a week and a couple cruises to houston it is acting up again??? when i first start it, it idles up to 1,000rpm then dies, then when i finally get it running it idles at 1,000 then sometimes idles up to 2,000rpm on its own, and other times it just dies if i dont countinuly give it gas, could it be that i need a tune? i know im getting enough fuel pressue, the gauge stays at high 30's, low 40's Oh and when it finally stays running for a while pretty good it starts to idle down to 850rpm?? and idles really choppy, and when i was messing with the VAN box i stuck my finger in it and opened the door slightly and it started to run perfect until i removed my finger then it went right back to the choppy idle then eventually dies....
NEED HELP PLEASEE, and if you want you can email me at cfish1992@yahoo.com Thanks, Cameron
Post by Stinger on Sept 7, 2010 3:20:49 GMT -5
You need to pressure test the system to locate any more vacuum leaks (if they exist). It will never be right if there are any leaks. You can make a "cap" to pressure test it out of a pvc pipe cap and a fitting for an air compressor hose. Clamp it into the system at the throttle body and pressure it up to 20psi or so.
Scan for codes (code scanner tool is $20 from parts store, eec-iv tester).
After you get codes, report back.
Post by mrsvo on Sept 7, 2010 12:13:47 GMT -5
well do i will go out right now and hook my dads computer and test for codes
Post by mrsvo on Sept 7, 2010 19:46:13 GMT -5
how do you check for codes?
Post by Stinger on Sept 7, 2010 22:31:23 GMT -5
Plug the scanner into the diagnostic port (near the passenger side strut tower) and then do as the scanner says. Different scanners require different steps after this point.
