Post by bgpickle on Sept 27, 2010 14:27:12 GMT -5
stinger which is better, and why? some turbos (t3 & t4) are water cooled and some are not? my 84 svo is not water cooled and the 88 merkur is water cooled, whats the deal? most aftermarket turbos i think are not water cooled. why?
Post by Stinger on Sept 27, 2010 19:56:01 GMT -5
Water cooling is marginally effective in a T3 because the cooling jackets have minimal surface area to dissipate heat. They do help to keep the oil from coking in the turbo if you shut it off when it's glowing hot. As long as you don't beat on it right before shutting it off, or let it idle for a minute before shutting it off after beating on it, you won't notice a difference.
