Post by erikjames13 on Mar 30, 2011 12:21:34 GMT -5
I am looking for an LA-3 Ecu and turbo coupe wiring harness so i can putt my XR4Ti motor in my 90' Ranger. also any info would be appreciated!
Post by FRANK/TurboTempo on Mar 30, 2011 20:21:40 GMT -5
I have one. a LA3
Post by erikjames13 on Apr 12, 2011 9:06:42 GMT -5
Still Looking for LA3, TC wiring harness, and any info. Will i need to swap anything else when i put these in my ranger like the VAM?
Post by bobbarker on Apr 14, 2011 23:46:11 GMT -5
Unless you have a way of tuning the LA3 like quarter horse or something else, then you will have to use a VAM that is matched to that ecu. If you had a tuner you could go speed density, or MAF if you wanted. I think injectors as well have to be the correct size for the LA3 comp.
