Post by Stinger on Feb 22, 2012 2:58:56 GMT -5
You guys kept asking for it so now we sell them: Universal Manual Boost Controller (Boost Valve)Simple to use manual boost controller. Increases torque even at stock boost level by creating faster boost response so the turbo reaches max boost at a lower rpm. Simply install between your boost pressure source and your wastegate/wastegate actuat. The side port goes to the gate/actuator and the bottom port goes to the compressor outlet or other boost source. Then simply dial in your boost pressure by turning the threaded top cap (threading in increases boost, out lowers boost) then tighten down the lock nut to lock it in place. Adjustable up to approximately 25psi with the supplied spring. Adding a stiffer spring or shimming the stock spring will increase the max boost available. Warning: Increasing boost can be dangerous for your engine. Be sure you have sufficient supporting mods, fuel flow, etc. to support the higher boost pressure or engine damage will occur. We are not responsible for damages. Has 3/16" (5mm) barbed inlet/outlet. Price: $ 35.00 Shipped with other ordered items, $40 Shipped individually www.stinger-performance.com/universalparts.html
don33
Post by don33 on Feb 22, 2012 23:11:19 GMT -5
is this essentially the same as the unit sold at boostvalve.com
Post by Stinger on Feb 23, 2012 1:11:14 GMT -5
Fundamentally yes.
Post by khantyranitar on Mar 16, 2012 9:08:16 GMT -5
Great job on adding this. I purchased mine a while back, but when I get closer to finishing up my other turbo car, I will be placing an order.
