Post by Stinger on Apr 28, 2012 13:15:42 GMT -5
Silicone 2.5" Coupler with 1.0" Tee Adapter for Adding a BOV/BPVThis kit includes a straight 2.5" coupler with a 1.0" tee port for adding a blow off valve or bypass valve to an FMIC kit. Can also be used to add a bov/bpv to a stock intercooler setup by using this coupler to connect to the throttle body. No need to completely cut the FMIC tubing to add this coupler, simply drill a 1" hole in the tubing and slide this coupler over the tube until it lines the tee port with the drilled hole. Add two 2.88" T-bolt clamps below to ensure the couplers don't blow off under boost. Our silicone couplers are constructed of 4 ply material, temperature rated to 392 degrees F, and pressure-rated to 43.5 psi at that 392-degree temperature. (Blow Off Valve Shown Below Not Included). Price: $ 30.00 Shipped www.stinger-performance.com/universalparts.html
boris
Post by boris on Jan 12, 2015 2:53:09 GMT -5
very cool Got one in a 3"?
Post by Stinger on Jan 12, 2015 14:07:34 GMT -5
No, just 2.5".
boris
Post by boris on Jan 15, 2015 1:59:16 GMT -5
dang
