fess40
Post by fess40 on Jul 16, 2012 20:29:56 GMT -5
I'm in need of both the feed and return nylon lines that connect the fuel rail to the the hard lines. Anyone got an extra set lying around?
Sent from my DROID RAZR using ProBoards
Post by chriscurtin on Jul 17, 2012 9:20:41 GMT -5
fess40
Post by fess40 on Jul 17, 2012 11:17:47 GMT -5
I wonder if they can make a couple of lines. I don't need the whole setup.
Post by lowstandards on Jul 18, 2012 5:20:51 GMT -5
Look up a company called dorman they sell it rolls of nylon fuel and duckbill fittings as well
fess40
Post by fess40 on Jul 18, 2012 7:56:11 GMT -5
I tried, but couldn't get the line to soften up enough with the hot water to get my fitting on the line. I ended up using the tubing flaring clamp and caulking gun method. Worked l like a charm!
Post by chriscurtin on Jul 18, 2012 11:55:07 GMT -5
Care to elaborate the caulking gun method? I haven't seen that one before.
Post by lowstandards on Jul 18, 2012 17:27:40 GMT -5
Yea water failed for me to and I used the caulk gun method....there's a thread on ls1tech that shows how to do it...long story short you use a caulk gun as a press and the tube flaring tool as a vise
fess40
Post by fess40 on Jul 18, 2012 22:42:01 GMT -5
Just do a google search. I found a good write up on a z28 site. Definitely won't do another line without it.
Post by in2fords on Jul 19, 2012 2:43:13 GMT -5
I know its kind of ghetto but I used high pressure fuel injection rubber hose and slipped it over the fitting on rail and hard lines, they have a nice lip that is used on the stock lines, I simply used a FI hose clamp, they are different then regular clamps. Seems to work good, as long as its FI hose and clamps I dont see a problem.
Post by lowstandards on Jul 19, 2012 15:44:42 GMT -5
I thought of using just fuel line but don't trust road debri and what not but I did wrap 3/8 vapor hose over the nylon line for extra protection
