Post by Stinger on Nov 11, 2008 17:59:53 GMT -5
Street Racing 4cyl Turbo Mustang VS 4.6L Procharged Mustang. The Supercharged V8 just can't handle the 2.3 Turbo power!
Post by chemicalexcuse on Nov 12, 2008 13:05:58 GMT -5
this is one of my all time favorite vids and i have shown it to countless people..i always wondered who's car it was and the engine specs
Post by Stinger on Nov 12, 2008 14:18:27 GMT -5
As stated, it is Bryan Hall, he's a "somewhat" local from the KC area. Here is his setup:
Chassis type: 84 SVO
short block mods/compression ratio/displacement: Stock block with JE pistons, Crower Sportsman rods stock length and piston are stock spec .030 over.
head/port work/valve size: ported stock big valve head. cam specs/degrees adv-ret: Esslinger 2277 you know the specs. intake/throttle body: Merkur intake non gutted with 95 Mustang TB by Huber Performance. intercooler: Spearco air to water (big one) nitrous system/shot size: Haven't used it. exhaust manifold: Stinger header turbo: Precision Turbo 61mm from MC Racing wastegate: Turbonetics Evalution exhaust size: 3" for now engine management: Accel DFI Gen 7 with WBO2 a/f ratio, total timing, boost: 12:1 a/f 26-28* total timing, 28-30lbs of boost. fuel octane/brand/leaded or unleaded: Track Tech 114 octane leaded fuel. hp@rpm: 485 rwhp last time on the dyno turned down. HP calculators say 540 rwhp with mph and ET. trq@rpm: 498 rwtq flex plate/flywheel: Stock flywheel convertor/clutch: Spec stage 3 plus transmission: Stock T5 rear/ratio/tire type/tire size: 4:10 gears, 26x10 ET Drags. race weight without driver: Need to weigh it but 3000lbs I think. ET/MPH: 10.32 @ 132mph open exhuast, 10.69 @ 130 through the exhaust including tail pipe.
Fuel pump/injectors: 255lph HP pump with stock lines and rail with 75lb injectors and MSD boost a pump.
next areas to be improved: Built C4 soon! Over the winter new motor hopefully with SVO alum head, custom intake, fuel system, and new ignition system.
Post by gearbanger510 on Dec 8, 2008 9:25:25 GMT -5
Local to KC eh? I saw this vid on the tube and was thinking to myself that it looked alot like "fairfax (??) Kc, Ks side...my buddy took me up there not too long ago (from Grove Ok). Lots of stuff there and lots of nice rides.....but this vid is killer.
Post by Stinger on Dec 8, 2008 15:31:34 GMT -5
Yeah, the V8 car is owned by a ProCharger employee from the area.
Post by alexs93lx on Dec 20, 2010 21:55:21 GMT -5
Great video!
I don't think my car is going to run nearly that well but it sure is encouraging to see these 4 cylinders getting it done.
Post by turbotyler on Jan 29, 2011 10:12:27 GMT -5
how much does a setup like that cost?
Post by Stinger on Jan 31, 2011 0:42:42 GMT -5
Depends how much labor you can do yourself, what your skill set is (for porting and such), and how much wheeling and dealing you do. To buy all the parts new and just bolt them on, probably $6000 or $6500. With enough used stuff, tons of your own skill and labor, etc., it could be done for $3500 or so.
I had a customer that wanted to make an "easy 400rwhp" in an SVO. I put together a combo of parts for him to buy to make it happen. He bought $2500 of stuff from me, I sent him to Bo for another $2800 or so, then he added in some small details and had a shop put it together. It made 420rwhp/450rwtq after a couple hours of tuning on the dyno.
Post by Jason on Jun 16, 2011 20:11:02 GMT -5
Does anyone have any additional pics/vids on Bryan's SVO? I've searched everywhere and can't find anything.
Post by Stinger on Jun 16, 2011 20:36:18 GMT -5
I can't find any at the moment (though I know I have them). There should be a number of vids of it running in Joplin Mo against some turbo vw's and such...pulling the wheels off the line.
Post by Jason on Jun 16, 2011 21:04:17 GMT -5
Thanks for the reply! Where and how do I find these vids? I've been looking for info on this car forever lol. Any help would be GREATLY appreciated!
Thanks, Jason
Post by Stinger on Jun 17, 2011 2:27:44 GMT -5
Like I said, I don't know where they are currently. I should have them on an old hard drive. I saw in a facebook update last week that he finally put the car back together and is ready to make some new passes. It went low 10's previously.
Post by Jason on Jun 17, 2011 8:23:01 GMT -5
How do I find him on facebook? Again, thanks for the reply's! And if you do come across some pics, that would be great!
Jason
Post by Stinger on Jun 17, 2011 10:42:09 GMT -5
Here is one from WFC8:
Post by Stinger on Jun 17, 2011 10:42:45 GMT -5
And another:
