Post by bgpickle on Jun 1, 2009 17:27:22 GMT -5
can i use the stock automatic tranny from a stock non-turbo 2.3 behind the turbo 2.3? will it hold up? do i need a different la3 computer or are the stick and auto the same computer? i want it to spool up and stay spooled up like the grand nationals did.
Post by Stinger on Jun 1, 2009 22:14:55 GMT -5
You can use one but don't expect it to hold up all that well. You'll need an auto ecu, or to put the lockup converter on a toggle switch.
Post by bgpickle on Jun 1, 2009 22:26:55 GMT -5
what tranny should i use so i can have overdrive, i dont want a c-4. it will be a street car. how can i tell which ecu is auto or stick?
Post by Stinger on Jun 2, 2009 0:26:17 GMT -5
LA3 and LA2 are stick, 8UA, LB3 are auto.
There is no cheap auto overdrive option that will handle decent power. If you don't plan to make more than 250hp, a large trans cooler will allow a stocker to last quite a while. Much more power than that though and you'll have issues without doing a performance rebuild on it using explorer internals.
You could always do an AOD swap using our 5.0 adapter plate?
Post by bgpickle on Jul 6, 2010 19:04:13 GMT -5
stinger thanks for all your help!!! i think i will be going with the aod, my son will be doing alot of commuting in traffic and wants and automatic. what should i do? i will buy your adapt plate, and then, what? look for a different ecu? how do i wire it?
Post by turbo23240sx on Jul 6, 2010 21:58:52 GMT -5
For what you will have in the AOD swap you could probably do a C4 with a GV overdrive unit. I can't even imagine an AOD behind a 2.3 sucking it dry of power, but maybe i'm wrong?
Post by bgpickle on Jul 12, 2010 16:49:48 GMT -5
why do the AOD's use that much HP to turn? the GV unit is pricey even thu the work well, its to much money for him right now! that is why i was thinking of the AOD.
