Post by Stinger on Jun 16, 2015 13:02:18 GMT -5
2.3 VAM Harness PigtailVane Air Meter (VAM) connector with 36" long wires. Use to turbo swap your non-turbo vehicle when using factory turbo ECU and air meter. Part # VAM-36 Price: $ 20.00Ford ACT Sensor Harness PigtailAir Charge Temp (ACT) connector with 36" long wires. Use when adding PiMP ECU to vehicle that doesn't have a factory ACT sensor, or when adding 87-88 TC ECU to earlier turbo vehicle. Part # ACT-36 Price: $ 20.002005+ Ford MAF Harness PigtailMass Air Flow Extension (2005 - Up): This is necessary when swapping or relocating the Mass Air Flow meter. The connector has 6 positions, as on the 2005 and later Ford Mustangs. Factory terminated with 36 inch wire leads. Part # MA-05 Price: $ 23.00www.stinger-performance.com/universalparts.html
