Post by Stinger on Nov 9, 2008 2:48:08 GMT -5
SIEMENS Fuel InjectorsSiemens injectors are ball/seat design with 6 hole diffuser disc which gives quick response time and very efficient operation at high duty cycles which make them great for high horsepower street/strip applications. Rated @ 43.5PSI Fuel Pressure. The ECM dictates if you must run low or high impedance injectors. Stock 2.3 Turbos require low Impedance. Performance advantages over pintle injectors ( Ford/Bosch/Accel/etc.):- Genuine, reliable Siemens Injectors - Compatible with alternative fuels (i.e. Methanol) - Robust Design - Excellent response characteristics - Quieter operation - EV1 Connector Price: $ 225.00 Shipped (Quantity: 4)
Post by bobbarker on Feb 17, 2009 8:07:47 GMT -5
Is there any benefit or harm in running an "oversized" injector? I don't really need an injector this big, but want to have that kind of power in the future.
Post by Stinger on Feb 17, 2009 14:08:17 GMT -5
Not really, as long as you have a way to control them...like a chip/tuner for the stock ecu or an aftermarket ecu.
