Post by wildstang on Jun 15, 2016 10:59:34 GMT -5
Here's my 1991 LX 5.0, I am the second owner.
It's a full H/C/I bolt on car, with a turbo kit in the future.
306 cubic inch 74' model heads with extensive porting, 58cc chambers, screw in studs and guide plates, 1.6rr TFS Stage 1 camshaft Trickflow Track Heat intake Bosch 24lb injectors Accufab Throttle body Billet MAF BBK CAI BBK Long tubes, Dr Gas X pipe, flowmasters A9L (currently no tune) T5 WC (rebuilt myself) SN95 8.8 with 3:55 gears, (looking into fox length axle swap)
Starting my LC2 wideband/PIMPxs install today! I'm going to try and take a good amount of pictures also.
Post by wildstang on Jun 15, 2016 11:01:36 GMT -5
A picture from the other day when I received my wideband setup.
Post by Stinger on Jun 15, 2016 13:24:14 GMT -5
Looks good!
Post by wildstang on Jun 20, 2016 7:52:43 GMT -5
I actually got further last week that I thought I would, fired it up Friday night. I drove it to work today, autotune changed 87 cells on the way here. Here's a few pictures I took.
I put the wideband controller behind the glove box, was planning on putting it under the center console, but it seemed too tight. Plus this way, I didn't have to remove any interior pieces.
Shot of the ecu before I installed jumpers.
This was the best option I had for installing the wideband bung, it's roughly 14" after the long tube collector before the junction in the X pipe. I know it isn't optimum distance, but it seems to be working correctly. Don't mind my welds, I don't weld often enough lol.
Post by wildstang on Jun 20, 2016 8:09:15 GMT -5
This was initial connection, had a few issues but figured them out quite quickly.
Just a few wires to coil up and hide, put the kick panel back on, and my install will be complete.
Tried the 2 step last night, but it was activating in neutral (clutch out), and with clutch in. So I just disabled it for now. I can make a new thread if you'd like, I'd like a second set of eyes to look over all my settings anyhow.
Post by Stinger on Jun 20, 2016 9:03:29 GMT -5
Good to hear it's up and running. Certainly post any PiMPxs related questions in the appropriate section.
Post by acobillas88 on Jun 20, 2016 14:33:17 GMT -5
Beautiful car!
Post by sophiblogger on Jun 22, 2017 15:20:52 GMT -5
OMG what a beauty!
