Post by denz on Sept 5, 2009 17:53:48 GMT -5
when i set cam on mark and crank on mark and install timing belt when going around crank to cam belt does not fall in tooth it has to be pulled up a little witch ends up turning crank to first mark before tdc will this be ok. just so you know this block was decked before i got it so i dont know how much was taken off. I had the head milled 3 thous. hope to here soon because im ready to put it in.
Post by denz on Sept 5, 2009 23:28:28 GMT -5
also do i have to worry about resistor wire when installing my 255 pump on my 88 notch
Post by Stinger on Sept 6, 2009 0:00:27 GMT -5
That's fine, once the belt is under tension it will line up properly.
I don't think the notch has the resistor wire.
