Post by awsx1686 on May 1, 2018 22:14:42 GMT -5
So my 2.3t build is in a 75 Triumph Spitfire, it currently has a Volvo coolant expansion tank that probably holds about 1qt. I've been told I need a bigger tank. Any suggestions on sizes, or any aftermarket or junkyard tanks that might work? Space is limited.
Post by Stinger on May 1, 2018 22:27:51 GMT -5
No idea on that one short of making something, or strolling through a junkyard with a tape measure.
fox4dr
Boosting 10 psi
Post by fox4dr on May 22, 2018 11:28:58 GMT -5
Assuming its the rad expansion tank.... Told by who? Is there a problem? If the Volvo tank functions and keeps the fluid off the ground why bother. These engines run cool if you have enough rad and airflow going thru it.
