Post by bluesn on Aug 16, 2018 6:49:23 GMT -5
If I’m planning on running the factory style injectors and sequence ins it necessary to purchase the Xs or just the pimp
Post by Stinger on Aug 16, 2018 9:13:34 GMT -5
Sequentail = PiMPxs, batch fire = PiMPx.
Post by bluesn on Oct 9, 2018 14:30:21 GMT -5
Hi so I’m doing the install. And got to this part we were talking about pin 8-19. So in my previous re pin I moved 8-19 and the car ran fine. I am confused as to what I’m supposed to do now with the pimp can. Leave 8 in 18 like I’ve always had it since I’m an sn95 repinned for fox or leave 8 and 19 out and wrapped?
Post by bluesn on Oct 9, 2018 14:34:26 GMT -5
I’m sorry. My voice text didn’t transfer correctly. With my an 95 I previously repinned it years ago and the directions had me move pin 8 to 19. Last we spoke I understood the Fox doesn’t use 19 so what do I do with 8 that was still in 19. Leave it like that or pull it out and wrap it up as well. So no 8 or 19?
Post by bluesn on Oct 9, 2018 15:38:26 GMT -5
Seems like I’m getting no fuel to the injectors when cranking?
Post by Stinger on Oct 9, 2018 16:02:48 GMT -5
As it says in the 94-95 Pin info in the FAQ thread, you remove and insulate pin 8 (which is pin 19 in your case since you previously moved it).
Post by bluesn on Oct 9, 2018 17:32:34 GMT -5
Please be patient with me. So pin 8 and 19 should both be empty now? I have read the repin info and your notes over and over and this seems to be the only thing I’m unsure of.
Post by bluesn on Oct 9, 2018 18:13:49 GMT -5
I’m sorry I’ve read the FAQ thread and the messages you sent to me personally and I’m still a little bit confused. So should the number eight and number 19 be empty now?
Post by Stinger on Oct 9, 2018 18:45:57 GMT -5
It's a single wire that's in one pin location or the other depending on vehicle application. PiMPxs does not use the wire at all. You can leave it in pin #19 like a stock fox body harness, or you can remove it and insulate it. Makes no functional difference as far as the ECU is concerned.
Post by bluesn on Oct 9, 2018 19:59:29 GMT -5
Ok thank you. I understand now. Now. Any idea why it’s seems like the engine doesn’t seem to be getting fuel even though there’s fuel pressure at the rail?
Post by Stinger on Oct 9, 2018 21:30:59 GMT -5
That question belongs in the PiMPxs support section in a new thread. You'll be best served if you upload your tune and a datalog of it cranking as well.
Post by bluesn on Oct 9, 2018 21:33:21 GMT -5
Ok will do!
