Post by turbo2300 on Dec 22, 2009 11:20:28 GMT -5
well i found my antifreeze leak, and its coming from the turbo, where i have no clue, i was under it for the clutch swap and i see it beading off the turbo..
how essential is the coolant to the turbo? some tell me its ok to not have it water cooled, some say its gonna ruin it... what gives?
Post by Stinger on Dec 22, 2009 13:45:39 GMT -5
If it's a T3, it's not really important, just make sure you let it idle down a bit before shutting it off.
Post by turbo2300 on Dec 22, 2009 13:51:07 GMT -5
yea its a t3 off an 86 iirc..
Post by fairmont on Dec 23, 2009 11:25:11 GMT -5
Do you need to plug the Turbo coolant hole or ok to just leave it open?
Post by Stinger on Dec 23, 2009 11:58:24 GMT -5
You can leave it open if you have to, though it may be less prone to cracking further if there isn't cold air blowing through it.
Post by fairmont on Dec 23, 2009 15:23:22 GMT -5
Is it the same with the ihi?
Post by Stinger on Dec 23, 2009 17:50:37 GMT -5
No, IHI's have better functioning water passages and should be ran with coolant.
