tyler
HX35
Jan 2, 2020 11:47:24 GMT -5
via mobile
Post by tyler on Jan 2, 2020 11:47:24 GMT -5
I currently have an 8 blade hx35, and have an opportunity to purchase a 7 blade if I want. I have read multiple contradicting points of views regarding the pros and cons of each. I would like to get a solid answer on which will perform better for more street use, around 350hp. Which will spool faster, etc. I would greatly appreciate any help. Thank you!
HX35
Jan 2, 2020 13:28:44 GMT -5
tyler likes this
Post by Stinger on Jan 2, 2020 13:28:44 GMT -5
It doesn't really change anything regarding spool or streetability as it's only the compressor wheel that is different. The fewer blades the better it performs at higher boost pressures and the more power it supports overall. Both of them will support 350hp.
tyler
HX35
Jan 6, 2020 16:36:37 GMT -5
Post by tyler on Jan 6, 2020 16:36:37 GMT -5
I have one more question. I recently purchased a .82 A/R housing for the HX35, as i had trouble finding a smaller housing. I am now reading that this housing is much too large for my application. What are your thoughts?
tyler
HX35
Jan 6, 2020 19:03:44 GMT -5
Post by tyler on Jan 6, 2020 19:03:44 GMT -5
Also, i purchases -4 AN line for the oil supply, and it appears to be 5/32 rather than 1/4". In your opinion, do you think this will neck it down to much and be too restrictive? THanks!
HX35
Jan 6, 2020 21:58:54 GMT -5
Post by Stinger on Jan 6, 2020 21:58:54 GMT -5
Most people run the stock exhaust housing with these engines and they are .82 or larger so it should be fine.
The Holset oil lines we sell for 2.3's is -4 AN so it's fine from that standpoint. Hopefully your line isn't rubber lined like the cheap eBay ones are.
tyler
HX35
Jan 6, 2020 22:25:27 GMT -5
Post by tyler on Jan 6, 2020 22:25:27 GMT -5
Sounds good, thank you! And i sourced them from Summit, so hopefully they are of good quality. Thanks!
