Post by gunnerrr on Apr 11, 2010 19:11:35 GMT -5
Ok so you dont piggie back of the the vam connector, you leave it alone an run new wire from the computer to the maf, the wires that are in the computer connector in pins 43,46,27,and 46, you take them out, and tape them off or do you splice into them. ? As far as the factory air temp sensor in the intake, is that sensor still being used, sence the 05 maf has it built in ? The reason i ask is the cars on a 2 post lift waiting on a few peices MM to come in, and i cant sit it on the ground yet, and i cant get in it either, ive got the computer out and the 1/4 horse is in stalled so hopefully ill have it back on the ground by mid week ,and im trying to get everything together by them for the maf conversion, i bought a VMP Blow-through 75MM MAF housing and HPX MAF sensor for it and i want to make sure i do it rite. Thanks for all the help seems to me you are the only person on the net that will talk to me about this topic , thanks again for all the help...
Post by Stinger on Apr 11, 2010 22:14:35 GMT -5
SvoJohn made that wiring diagram (he's a member on here) so I can't say for sure. The only wires that "might" be spliced to rather than cut and taped off would be the signal return wires. The rest can't share any other signals and work correctly. You might want to send John a PM and see if you get a response.
