Post by tbird86 on Apr 29, 2020 11:57:10 GMT -5
On my 86 turbo coupe. When I put the center mount header on it, I ran a coolant line from top of turbo to the coolant line near valve cover. Then I plan on running the line from bottom of turbo to the bottom of engine block. If I'm looking at this correctly this is reverse flow from factory. Will this be an issue?
Post by Stinger on Apr 29, 2020 13:48:51 GMT -5
It sounds like you didn't rotate your turbo center section when mounting it on the turbo? This won't work. Oil feed line has to be on top and return line on the bottom (stock orientation) which then puts the coolant lines on the sides, not top and bottom.
Post by tbird86 on Apr 29, 2020 16:19:06 GMT -5
I did not rotate the center section. I'll look into that.
