Post by tbird86 on May 1, 2020 21:47:41 GMT -5
I'm installing catch can on 1986 turbo coupe. My pimp is not up and running yet. Do I need the vacuum switches That are mounted behind the ps shock tower where you mounted your catch Can? Also in front of the ps shock tower are a couple more, one looks like a map and the other was round with 2 vacuum lines.
Post by Stinger on May 1, 2020 22:20:29 GMT -5
EGR stuff is behind the strut tower (not needed), MAP and boost control solenoid are in front of it (not needed, though you do need some sort of boost control). We offer manual and ECU based boost control.
Post by tbird86 on May 2, 2020 8:07:08 GMT -5
I got one of your downpipes that eliminated the stock wastegate. Is an a/m wastegate not all I need?
Post by Stinger on May 2, 2020 12:45:28 GMT -5
If you want to run off wastegate spring pressure then yes, that's all you need. If you want to be able to adjust boost pressure without swapping out wastegate springs, you need a boost controller to do so. This is the case regardless of ECU.
Post by tbird86 on May 2, 2020 13:10:21 GMT -5
Ok. Thanks.
