Post by perri2300 on May 12, 2020 17:02:48 GMT -5
I am looking for a solution for Microsquirt and a wire harness for my Father's 302 swapped Ranger. The 302 is out of a 96 Ford Explorer, so it is OBD2. I understand that in order to use something like Microsquirt, he would need to use a distributor instead of coils. Do you guys sell a wire harness that would work with Microsquirt?
Post by Stinger on May 12, 2020 19:04:07 GMT -5
Microsquirt doesn't require a distributor.
We don't offer a V8 Microsquirt harness, only 4 cyl. Only real difference is the addition of 4 more injector connectors and possibly the wire length for a few sensors but we don't offer it for V8's because we don't think it's a viable option for most V8's because of the limited number of programmable I/O's.
Post by perri2300 on May 12, 2020 20:36:06 GMT -5
I think some companies make a Microsquirt adapter for the SN95 mustangs. Basically what I think I need to do is find a mustang wire harness and buy the adapter for Microsquirt and Microsquirt itself.
Thanks for the reply!
Post by Stinger on May 12, 2020 20:52:54 GMT -5
They make adapters for Fox Bodies as well. The SN95 deal is just a modified version of the original Fox Body version.
Keep in mind that we'll sell Microsquirts cheaper than anyone.
Post by perri2300 on May 13, 2020 18:02:16 GMT -5
When I get the wire harness, I will definitely order Microsquirt from you guys.
