Post by tbird86 on May 18, 2020 11:50:56 GMT -5
I'm plumbing my bypass valve. What would you recommend as the smallest thread for the place I tap into for my 1 inch hose? I found a place that is 1/2npt if that hole is big enough.
Post by Stinger on May 18, 2020 11:59:05 GMT -5
The ID of the hole needs to be the same (or very close to the same) size as the bypass valve ID. So the 1" hose that you slide onto the outlet of the bypass valve will be the same size hose as you put onto the fitting on the inlet and the inside diameters will be comparable.
