Post by mstng93ssp on Jun 10, 2020 4:18:43 GMT -5
Quick question. I have my Pimpxs setup in my 93 Mustang and it works great. I just swapped engines (now a 306) and am about to setup my Pimpxs with my new engine. When I create a new project (for the new engine) and go through the initial setup will the "no fire" feature still be enabled until I load my tune so I can set initial timing prior to startup like it did when I first setup my original engine?
Thank You
Post by Stinger on Jun 10, 2020 12:22:05 GMT -5
No, the "no fire" isn't a feature, it's just the tune we load in it before shipment doesn't allow fuel flow. If you change your tune's required fuel value to 0 then it won't fire the injectors.
Post by mstng93ssp on Jun 11, 2020 3:40:58 GMT -5
Got it. Thanks for the reply.
Chris
