Post by oneowner88lx on Apr 1, 2010 11:24:46 GMT -5
Make sure timing belt has not jump.
Post by Stinger on Apr 1, 2010 14:09:04 GMT -5
Is there spark at the plugs?
Odds are after a backfire the cam timing is off.
Post by dgmann995 on Apr 5, 2010 20:46:53 GMT -5
it was the distributer gear and auxiliary shaft was striped how do u replace the auxiliary shaft thanks
Post by Stinger on Apr 5, 2010 21:16:58 GMT -5
It pulls out of the front of the block after you remove the auxiliary gear and retainer cover. You'd be best off the pull the oil pan and make sure there isn't any debris floating around in there. If it gets in the oil pump it will lock the pump up and strip the new gear set.
