Post by dgmann995 on Feb 4, 2010 9:06:40 GMT -5
hey i have a turbocoupe it has new tbs new 255 hp fuel pump new o2 and tune up but when it idles it has a miss and when driveing it has a miss but its not all the time and the codes are 28 27 14 41 42 thanks for any help
Post by merc460 on Feb 4, 2010 10:22:48 GMT -5
28 Vat sensor out of Range 27 ?? 14 Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall. 41 HEGO sensor circuit indicates system lean 42 HEGO sensor circuit indicates system rich looks like 14 is the problem the Vat code maybe it was cold out at 32F it should read 5800 ohms and at 185F it should read 300ohms the O2 codes maybe by products of the engine miss or old codes from before you changed the O2 sensor.
Post by Stinger on Feb 4, 2010 12:04:39 GMT -5
I agree, looks like the pip in the distributor is failing.
Post by oneowner88lx on Feb 4, 2010 12:24:58 GMT -5
The VAT, ECT, and ACT sensors will all throw an Out of Range code if the sensor is below 50 degrees when you run the KOEO test. Changing the PIP in the distributor requires a press to get the gear on and off. If it were my car I would either get a new PIP put in or get a rebuilt distributor from www.rockauto.com.
Post by dgmann995 on Feb 15, 2010 19:34:44 GMT -5
well havent changed pip yet but now car will not idle it fluxuates from 1200-800 sorry for the spelling its hard to start has a real bad miss all the time maybe a plug went bad going to change them and see changing pip as soon i have the money thanks
Post by Stinger on Feb 15, 2010 22:30:23 GMT -5
Gotta fix all known problems before diagnosing "new" problems.
Post by 93stangnow23t on Feb 17, 2010 22:33:36 GMT -5
I would say my car is doing the same thing let me know if you figure it out cause I've been trying to figure it out for the pas month.
Post by dgmann995 on Feb 23, 2010 17:53:25 GMT -5
its was the fuel pressure regulater running like a champ no miss
Post by dgmann995 on Feb 23, 2010 17:53:46 GMT -5
thanks guys
Post by dgmann995 on Mar 31, 2010 12:20:27 GMT -5
well im back now car will not start at all put new pip in ran good for a week then back fired and now its not starting checked coil has power in and out of it but no spark out of the distributor. getting fuel
Post by Stinger on Mar 31, 2010 15:26:18 GMT -5
What do you mean by "checked coil has power in and out of it but no spark out of the distributor."
By power do you mean voltage or spark?
Post by merc460 on Mar 31, 2010 16:56:13 GMT -5
Check to see if the rotor in the dist is turning?
Post by oneowner88lx on Mar 31, 2010 20:03:42 GMT -5
Check for codes too.
Post by dgmann995 on Apr 1, 2010 7:50:42 GMT -5
there is spark out of the coil and the rotor is turning. the only code is system pass code 11
Post by merc460 on Apr 1, 2010 9:10:45 GMT -5
the coil wire from the coil to the dist maybe bad?
