Post by corerider on Jul 9, 2020 10:57:36 GMT -5
I couldn't find an answer to my question in searching...
I'm looking to go turbo soon, but would like to order/install the PiMPxshift before I do the turbo to get to know the system. Should I order the N/A or turbo system? Is the difference just the base tune?
Post by Stinger on Jul 9, 2020 12:55:01 GMT -5
The difference is just the base tune. If the cam isn't going to change then order the n/a system.
Post by corerider on Jul 9, 2020 14:55:45 GMT -5
The difference is just the base tune. If the cam isn't going to change then order the n/a system. The cam will stay stock... just going from N/A to S366 turbo a bit later. Can I get the turbo base tune at a later time?
Post by Stinger on Jul 9, 2020 19:30:40 GMT -5
The tune you get will be pre-populated for boost as well.
Post by corerider on Jul 10, 2020 11:34:01 GMT -5
Okay thank you!
