Post by denz on Feb 15, 2010 19:47:44 GMT -5
so i got my 16v volvo head back from pete and ready to move on. But my question is should i have it ported or not. this car will be my daily driver weekend strip beater. dont get me wrong i want all the power but i still want reliable. i plan on tunning this with ms. what do you guys think.
Post by Stinger on Feb 15, 2010 22:31:30 GMT -5
Porting won't change reliability. It comes down to how much power you want to make on pump gas and how much you want to spend. If you goal is less than 350rwhp I'd say don't bother with porting the Volvo head.
Post by denz on Feb 15, 2010 23:12:06 GMT -5
thanks stinger, but i guess my ? is more about road manners. ya no can i enjoy driving it to work still ? allright i want 400 so a little port work will be needed. i was just wondering if i should spend the money and time. you know porting if you cant do it you have to wait.
denz
Post by Stinger on Feb 15, 2010 23:37:16 GMT -5
Porting won't hurt street manners, it will actually make more power everywhere so it would make it drive a bit better out of boost. That being said, the head flow says porting isn't needed for 400hp. Porting will allow you to make the power at a lower boost level though (which helps if you are trying to do it on pump gas).
Post by denz on Feb 16, 2010 0:08:01 GMT -5
yes 93 oct. what size inj will i need for 400? and with ms can you help tune over comp. or no someone. i plan on buying my kit from wilson but i see them cheaper at other places, can you ex plane this.
denz
Post by Stinger on Feb 16, 2010 1:49:49 GMT -5
I've tuned some cars with Megasquirt over the internet before. Not super difficult, just time consuming.
55's will get you close to that hp level, even a little over it with a little more fuel pressure. 65's or 75's would suffice for much more than 400.
The reason the Wilson MS kit is more expensive is because it's a complete ready to run kit (all configured for your setup and soldered together) rather than just a generic case full of components that you have to solder together to fit your needs.
Post by denz on Feb 16, 2010 8:00:04 GMT -5
so for ease it is best to get the one form wilson that is what i was thinking. with ms i can go with 65 lb inj and still be streetable.
denz
Post by Stinger on Feb 16, 2010 13:25:33 GMT -5
You can run 120's and still be streetable if the tune is correct.
Post by denz on Feb 16, 2010 20:51:21 GMT -5
good thanks stinger
Post by sleepinsol on Feb 17, 2010 19:25:46 GMT -5
the more hp your motor makes n/a, the more its going to make on boost with lower boost levels (up to a point). porting the head wont hurt at all, and in fact will make your car more responsive out of boost (like an n/a car). forgive me if this has been said already, i skimmed the thread before replying. good luck!
Post by denz on Feb 17, 2010 21:12:20 GMT -5
sleepinsol thanks for the info. i see what your saying. my porter says not to do much till i get some better cams, he says with a little work he will fine tune it for the stock cams i have now.
denz
Post by sleepinsol on Feb 17, 2010 21:24:46 GMT -5
dial the cams in with the turbo youre using. no sense in getting huge cams if your turbo wont spin to the higher rpms (ie like an ihi dies out at 5k rpm while the stock slider cam makes power to about 6k rpm). the porting wont hurt either way.
Post by denz on Feb 18, 2010 1:17:59 GMT -5
t3/t4 hybrid
