Post by nic86hldr on Feb 25, 2010 16:48:45 GMT -5
i have the stock fan in my 4cyl 86 capri and i dont think that will work with your FMIC setup i bought. So i was gonna switch out my fan with the sunbird fan u used...did you need the pigtail from the sunbird to wire it to or did it directly connect to the ford fan connector? thanks and sorry if its a dumb question
Post by Stinger on Feb 25, 2010 23:29:15 GMT -5
It's just two male spade connectors on the fan...I just put two female spades on the stock wiring and plugged it in. Make sure you don't put the wires backwards or it will blow air the wrong way.
Post by nic86hldr on Feb 28, 2010 0:43:52 GMT -5
thanks! i just purchased one so i cant wait till it gets here.
