Post by jasonsvolmo on Sept 26, 2020 2:03:37 GMT -5
Young svo beginner here,I try to limit myself on questions, I only ask after I’ve found nothing on forums or talking to people in person With that said, I have a la3, 35 pound injectors in my svo, I’d like to find good drop in injectors to replace the old ones I have now in fear of running lean. I would assume I could purchase slightly higher pound injectors and a fuel regulator and just turn down the fuel at the regulator to match? Also, will the kirban adjustable fit the old inline intake/fuel rail? Thanks!
Post by Stinger on Sept 26, 2020 4:32:40 GMT -5
Welcome. Don't worry about limiting questions.
You can have your injectors cleaned and flowed for around $10-$15 each so that's a viable option as well.
You "can" use slightly larger injectors and turn down the pressure but there will be no performance benefit and the spray pattern won't be as good as the right size and pressure.
Note the injectors have to be low impedance.
FPR fits on the inline intake style rails as well.
