Post by bbarrera on Sept 28, 2020 23:29:19 GMT -5
I’m currently swapping out the stock ihi turbo from my 88 tc engine and going to a .60 t3. As far as I’m aware I’m pretty sure the t3 is a roller bearing turbo as opposed to the ihi being journal bearing. Do I need to do anything with the oil feed line such as a restrictor or anything? Thanks
Post by Stinger on Sept 28, 2020 23:51:31 GMT -5
They are both journal bearing. You don't need a restrictor, though it's a good idea to replace the feed line if you're using the stock hard line as 1) there is likely a hard "crust" stuck to the inside of that line and when you start messing with it that stuff can break lose and prevent your T3 from getting oil and 2) the line is different between the two turbos so you need to modify or replace anyway. We sell braided lines for this reason.
