P14
Oct 13, 2020 11:22:34 GMT -5
via mobile
Post by Hueneme805 on Oct 13, 2020 11:22:34 GMT -5
Hello I’ve been getting this code recently p14 and making the car buck when idling and that’s only sometimes. I’ll just turn it off let it sit for a couple of minutes and restart with no issues. I’ve researched and it has something to do with ignition pick up was erratic. Could this be a ignition pick up going bad? Any one had this issue before.
P14
Oct 13, 2020 13:59:26 GMT -5
Post by Stinger on Oct 13, 2020 13:59:26 GMT -5
It would make me suspect the PIP, or faulty wiring that's temporarily losing connection when the engine is shaking.
P14
Oct 15, 2020 15:05:13 GMT -5
via mobile
Post by Hueneme805 on Oct 15, 2020 15:05:13 GMT -5
It has been doing only at cold starts then I guess it warms up.🤔
P14
Oct 31, 2020 15:29:10 GMT -5
via mobile
Post by Hueneme805 on Oct 31, 2020 15:29:10 GMT -5
I just today revived new pip and installed it. As I started the engine to set timing and achieved timing at 10 tdc the car starting acting up again after2 min. Remind you I cleared code (hopefully)before starting engine. Rescanned and p14 pop up again. Possible bad part or harness maybe. I haven’t checked for broken wires ?
P14
Oct 31, 2020 17:22:15 GMT -5
Post by Stinger on Oct 31, 2020 17:22:15 GMT -5
Parts can certainly be bad out of the box but I'd suspect wiring.
P14
Nov 1, 2020 11:39:16 GMT -5
via mobile
Post by Hueneme805 on Nov 1, 2020 11:39:16 GMT -5
Shannon are you saying wiring at TFI connection harness? The wires are looking bent and folded at the TFI harness. Can you refer me to a dealer who sells tfi harness?
P14
Nov 1, 2020 14:36:02 GMT -5
Post by Stinger on Nov 1, 2020 14:36:02 GMT -5
You need to test/diagnose the problem, not just throw parts at it. Do the wiggle test, do a visual inspection, etc.
P14
Nov 20, 2020 19:24:29 GMT -5
via mobile
Post by Hueneme805 on Nov 20, 2020 19:24:29 GMT -5
So current to this I have a msd ignition box and out of curiosity I disconnected the box and just kept stock. The problem has gone away so it seems I had a bad ignition box or harness that connects to coil pack. Car is running normal and no more p14.
Post by Stinger on Nov 20, 2020 23:44:30 GMT -5
Failed MSD box is VERY typical so that's what I'd suspect at this point.
