Post by crouton23t on Oct 26, 2020 11:48:48 GMT -5
Hey there I’ve set up my ignition based on a 1994 ranger with an ignition control module and I have seen the timing light flash once and now I can’t get spark. Been through the whole harness and cleaned up loose ends still having the issue.
Post by Stinger on Oct 26, 2020 16:52:40 GMT -5
You need to post in the ECU section that matches your ECU type, and you need to attach the tune so we can review your settings.
