Post by ranger87 on Oct 28, 2020 12:26:05 GMT -5
Was trying to find some mounts cant find anything other then stock for a 4x4 ranger there are 2wd mounts but the mounts look different on how they mount trying to go away from stock already broke the stock style mounts thanks guys
Post by Stinger on Oct 28, 2020 14:36:15 GMT -5
I don't think anyone makes aftermarket versions. If you can get another stock one I'd likely just put a limiting strap on the torque side, or even do like the SVO's had and put a small shock on that side to slow down the engine pulling. If you do a limiting strap, using a rope rather than a chain will be less noisy and also not be so rough since ropes have a little stretch where a chain is solid once it's tight.
