Post by mustanginaz on Oct 28, 2020 23:31:00 GMT -5
is it possible to use a set of brown top injectors in my 1984 svo with the stock ecu
Post by Stinger on Oct 29, 2020 0:02:15 GMT -5
Brown tops are 35lb and stock SVO green tops are 30lb. You should not use them with the stock ECU UNLESS you have an adjustable fuel pressure regulator so you can lower the pressure to make them flow closer to 30lb. Only time this would be advantageous would be if your green tops are bad/leaking and you have some 35's already.
