Post by zodiac on Nov 2, 2020 17:57:54 GMT -5
Just picked up a ranger project, timing was way off. Set timing 10dbtd found out injector 3 wasn't firing. Bit the bullet and got a new harness and PiMPx. Got it fired up but it started popping out of the intake. Wasn't sure what injectors were in it so I just installed 80lb injectors. Unsure on what's causing it, just ordered a timing pointer to better tell the timing. Here's a short video
Here's a link to a tune and datalog
Post by Stinger on Nov 2, 2020 19:47:53 GMT -5
That doesn't really sound like backfiring into the intake but it does sound like it's running on 3 cyl or has one low compression cyl. Have you verified you have spark and fuel in all 4 cylinders now? All 4 plugs look similar?
Post by zodiac on Nov 8, 2020 18:31:05 GMT -5
