Post by Hueneme805 on Nov 20, 2020 19:27:58 GMT -5
Doing an adjustment on tps, and as I’m setting voltage. The voltage just keeps bouncing around not staying consistent. Does this mean a bad tps sensor?
Post by Stinger on Nov 20, 2020 23:45:07 GMT -5
Typically, yes, unless it's wiring. If you're probing right at the TPS then wiring isn't the issue.
Post by Hueneme805 on Nov 22, 2020 2:05:15 GMT -5
Does the tps sensor you sell comes with a gasket?
Post by Stinger on Nov 22, 2020 13:53:26 GMT -5
No
Post by Hueneme805 on Nov 23, 2020 21:42:39 GMT -5
Does it need a gasket or no gasket is fine?
Post by Stinger on Nov 23, 2020 21:53:30 GMT -5
There is a seal on the throttle shaft so I don't think it needs a gasket. Seems like the gasket would get messed up when trying to adjust the TPS.
