Post by trey6097 on Nov 30, 2020 20:59:28 GMT -5
Wanted recommendations on idle air valves on which ones some of you guys are running for the 2.3. Because I've went through two duralast and one other brand from rock auto that did not help my issue. And I also installed a new tps which was set a little too high cause I was fed up at I think 1.00 instead of .90-.95 like the recommendation for that that I've seen. But I figured it would be ok. Because it seems like my issues are more iac related because of how bouncy my idle is and it stalling constantly etc. I've followed stingers protocol on resetting my idle numerous times down to every step. At this point I just want a iac. Recommendation to see if maybe the ones I've bought are bad as motorcraft isn't a option none I can buy. Yes I've replaced my spark plugs and wires gapped correctly I even bought a new ignition coil and temp sensor as a faulty temp can affect it.
Post by Stinger on Nov 30, 2020 23:31:44 GMT -5
It's highly unlikely the IAC is the problem if you've been through the original and 3 new ones and it's not fixed the problem. They are also something that rarely fails and typically just getting dirty is the main cause of an issue.
I'd look for vacuum leaks. I'd also scan for codes if you haven't.
