Post by turboragtop on Dec 2, 2020 1:59:35 GMT -5
The air charge temp sensor has two wires coming out of the connector. They are the same color. How is this sensor supposed to be connected properly? Thanks
Post by turboragtop on Dec 2, 2020 13:39:22 GMT -5
Per your PIMP ENGINE MANAGEMENT 2.3L WIRING DIAGRAM: The ACT/IAT SENSOR connects one wire to pin 25. The other connects to pin 46 SIGNAL RETURN. Does it matter which wire connects to pin 46 SIG RET? Thanks
Post by Stinger on Dec 2, 2020 14:46:14 GMT -5
Doesn't matter, works the same either way.
