Post by turbo75courier on Jan 8, 2021 3:58:44 GMT -5
I have a 88 Turbo Coupe 2.3 turbo engine in my 75 Ford Courier and only have about 1 inch of clearance between the water pump and radiator I'm only running one pulley and I ground down the nipple that was sticking out in the center of the pulley I was wondering if there was another water pump I could run that won't stick out so far I would like to move my fans to the engine bay from the front to allow more room for a intercooler at the moment I am running a air to water intercooler
Post by Stinger on Jan 8, 2021 14:34:11 GMT -5
I'm not aware of one, other than fabricating a plate to put where the stock pump goes and running an electric pump mounted elsewhere.
What about running some smaller fans (8" or 10") on the sides/corners so the fan isn't where the pump is?
Post by turbo75courier on Jan 8, 2021 15:52:01 GMT -5
ok thank you stinger
