cj
Post by cj on Jan 24, 2021 20:18:43 GMT -5
Hello, I am going to change my fuel pump to something larger than stock. I currently have a Pimpxs, 60 lb injectors, Ranger roller cam, stock Thunderbird turbo, 2 1/2in exhaust and nothing ported. I want to go the single pump route. Current plans include ported intake and exhaust, FMIC, 3in exhaust . Future plans will include larger turbo, external BOV, Fuel rail with adjustable regulator and Probably a BoPort 3.xx head along with switching over to sequential fire. I will more than likely be running ethanol at this point and will need larger injectors. My question is this, is there a fuel pump you can recommend that will fit my situation?
Post by Stinger on Jan 24, 2021 22:31:45 GMT -5
E85 means you'll likely need more than a 255 pump can handle so our 340lph pump is likely the best option. You'll need the adjustable regulator to use it as it will over-run the stock regulator.
cj
Post by cj on Jan 27, 2021 20:37:57 GMT -5
Thank You for the information.
Is there a write-up or information that is available on how to go from a two pump system to single pump?
Thank You, Cj
Post by Stinger on Jan 27, 2021 21:39:48 GMT -5
I think there is one on the SVOCOP forums. There is more than one way to accomplish the same end result though.
Post by krunex on Jan 30, 2021 13:20:40 GMT -5
Thank You I have ordered the parts and will be looking at all the different ways to install it. I hope this will help to cure my high VE table as discussed in another thread about a possible failing fuel pump. Of coarse on the latest drive the water pump failed....
Thank You, Cj
