Post by hunterreid on Feb 9, 2021 13:57:32 GMT -5
I recently purchased an 84 SVO with an 86 Turbo Coupe engine. Just had the motor rebuilt and finishing up putting it back together, but I am missing the oil separator that is mounted to the block, and after a few days of searching I can't find one anywhere. So my question is, can anyone possibly point me somewhere I may be able to find one, or can I bypass the separator all together? Thanks
Post by perri2300 on Apr 6, 2021 0:19:43 GMT -5
Dang, I wish I would have seen this a while ago. Are you talking about the thing that people generally call a "oil cooler" or "coolant warmer" that the oil filter threads on? If so, I have one if you still need it.
Post by Stinger on Apr 6, 2021 1:03:22 GMT -5
No, he's talking about the breather that vents the crankcase and connects to the PCV valve hose. Mounts right next to the oil cooler.
Post by tutulate on Apr 7, 2021 7:50:04 GMT -5
Shannon. Is there a trick to getting the separator to fit tight into the block? Every time I have removed one( such as when the block is rebuilt), they are a pain to get out but then they spin around when I re-install them.
Post by Stinger on Apr 7, 2021 12:18:32 GMT -5
It's a press fit so if it's loose, it shrunk/wore out the OD when removing. A little RTV can tighten it up.
Post by n2xlr8n on Apr 19, 2021 7:58:22 GMT -5
I have an extra- shoot me a PM.
