Post by lakenheath24 on Mar 7, 2021 12:34:59 GMT -5
Hi, I am looking for some installed pics of the wastegate, downpipe and BPV setups so I can get an idea of what I need to do.
The exhaust is a Randy Heinlein center mount header with a Stinger style oil drain line and a Holset H1 turbo.
I thought there were pics on here, but I cannot find them.
Thanks!
Post by Stinger on Mar 7, 2021 13:23:34 GMT -5
What specifically are you trying to figure out?
BPV is unrelated to the wastegate and downpipe.
Wastegate bolts to header, outlet of wastegate dumps to open atmosphere, or gets routed back into the downpipe.
BPV connects to intercooler tubing and the outlet connects to the turbo inlet pipe/hose (between turbo and air filter).
Post by lakenheath24 on Mar 8, 2021 3:50:28 GMT -5
Well, my project has been sitting 8 years and I have forotten much! There is an option on the wastegate for hose length, so I was just trying to figure out how much I need.
Post by Stinger on Mar 8, 2021 13:24:11 GMT -5
That just depends on how far it is from your wastegate to where ever you're going to hook the hose that connects to it (typically through a boost controller). The hose would connect to the vacuum tree, or turbo outlet port, or the intake manifold, then go to the boost controller, then to the wastegate.
BPV hose would connect to vacuum tree or intake, not the turbo outlet port.
Post by lakenheath24 on Mar 8, 2021 15:22:02 GMT -5
OK thanks, like I said, its been eight years. I just wanted a visual reference to look at where things go.
