Post by svt4lifez on Jun 22, 2021 15:16:36 GMT -5
Figured I'd post this up since I have had a few questions come my way about my build. I also hope this can help anyone who would like to put something like this together as well. There is tons of info out there but over close to 30 years there has been a lot of regurgitated false info on the internet.
Anyways, I also like showing off the ride since its been a fun project the past few years taking my time putting together and the PiMPxs has been a great product so far.
94 Cobra - Black with Cloth Interior:
351w Stock Block Stroked/Bored to 408ci
Forged SCAT Rods
Forged DSS Pistons
Cast SCAT Crank
Dart Pro1 195cc Heads
Trick Flow R Long Runner Intake
Howards Cam - pretty mild I dont remember exact specs off the top of my head 227/233 112lsa .600 lift?
Professional Products 75mm TB
Trick Flow 75mm 94-95 intake Elbow
Custom Intake piping into fender mainly BBK piping in engine bay.
Champion 3 core Radiator
BBK 351w Swap Long Tube headers
BBK off road H-Pipe
SLP LM1 Catback
Quantum fuel pump hanger
Walbro 450lph Pump
-10an Feed split to 2x -8an into rails
2x -6an to Regulator
-8an Back to tank
Aeromotive Fuel Rails
Ford / Siemens Deka 80lb Injectors
Fore Adjustable Regulator
Tremec 3550 Transmission
FRPP Aluminum Driveshaft
SPEC Stage2+ Clutch
Maximum Motorsports Clutch Cable
UPR Firewall Adjuster
Steeda Clutch Quadrant
Steeda Driveshaft Spacer
Pro5.0 Shifter
UPR Adjustable Shifter Handle
Tokico D-Spec Adjustable Struts/Shocks
Prothane Urethane Bushings throughout Front suspension
UPR Spherical Rear Upper Control Arms
Urethane Rear Lower Control Arms
Spherical Caster/Camber Plates
Eibach Front springs
H&R Rear Springs
Ford 8.8" w/ Eaton Truetrac
31 spline axles
3.73 Rear Gears
Swar axle bracing
Axle Tubes pinned
10.5" Deep dish Chrome 95 Cobra R style Wheels in Rear
315/35/17 Mickey Thompson ET Street R
9.5" Chrome 95 Cobra R wheels in Front
275/40/17 Mickey Thompson Street Comps
PiMPxs ECU
I have gone through this car and replaced just about every thing (sensors, accessories, switches etc.) I had the car repainted and replaced or restored any trim pieces that were degraded. I am sure I am missing some stuff but that is most of it.
Future plans are for a Tremec T56 Magnum or TKX and to put a Turbo on it for 6-700hp. This is mainly a have fun on the weekend street car and occasionally I will run it at the track. I'm still trying to figure out what the smallest turbo I can get away with for low boost and meet my power goals.
